Popping between CD quality and MQA/Hi-Res Tracks
There is an annoying popping noise between tracks that differ in Bitrate/format.
Bluesound Node (gen 3)
Roon/Tidal Connect/Amazon Music app. Doesn't matter.
Please advise.
Happens with BluOS app as well with above services...
Me too. Tidal via BluOS. Node (3) straight into power amp.
Is there a solution yet?
Hi All - Update on this issue...
We are continuing to investigate and hope to publish an update shortly but it appears to be happening when a sub-woofer is attached that the muting switch is not firing. Please continue to check back for updates... and thank you for your patience...
I have this same problem (touched upon in another thread), but there is no subwoofer involved here. In fact, it is a very straight setup, analog outs of the Node (N130) going to a pair of active speakers. No subwoofer, no external DAC.
My subwoofer has speaker level inputs, that was my work-around.
6 comments
