Vault - High Pitched continuous whistle
AnsweredCan anyone help?
I have a Vault which has a continuous high pitched whistle. Any ideas on how I get rid of it, the noise that is.
Getting to the point where the noise is driving me mad!
Hardly HiFi.
Hi Seppi
Thanks for replying. Ive tried what you suggested and it appears, for now anyway, to have solved the problem.
You're a genius!! Thank you so much.0 -
We have the same problem with our Vault. I can’t see the reply on the question of Leigh Crant above, what seems to get the sollution. Can anyone help us out, cause we are experiencing a similar madness…
-1 -
The high pitched whistle in my vault was due to a faulty power supply. I had mine replaced for around £100 and the problem has gone away.
Thank you for your response. We are going to look for a new power supply.
4 comments
