Subwoofer output low volume
AnsweredThe Sub out volume is extremely low. It was workign previously but stopped working - could it be related with recent firmware update?
I can tell that the sub is receiving an audio signal only because i can feel the sub speaker vibrating very faintly - the signal volume is extermly low.
Tested the sub on a different system and is working fine.
Subwoofer toggle is switch on in the the audio settings. Corssover setting at 100Hz.
I did a Node factory reset - issue not resolved.
Hi Nikos,
Please send us a support request directly through the BluOS Controller app. This will automatically include a diagnostic log from your NODE, which will help our Support Crew investigate the low Subwoofer Output level and determine what may be causing the issue.
Once the request is submitted, a member of our Support Crew will reach out to you soon to assist you further.
