Not possible to connect node2 to wifi
    Seppi Evans
    You could try a factory reset (there is no such reset button but a sequence) but with the red led best best would be to contact support support@bluesound.com
  • Jean-Marc
    Same here. Did you get any useful help from support? I didn't. Very disappointed
  • Herman Phalen
    No the machine was broken, probably needed reprogramming. I sent it back to the vendor.
