SInce BluOS 4.16.6 Bluesound breaks roon connection
AnsweredHi,
I have 3 different devices (Pulse Mini 2i, Flex and NAD M10v2). Since the last update my devices are shown as roon tested and not as roon ready. I am only able to connect via airplay2. I opend a ticket over the NAD device side.
Is there anybody with the same problem?
Hi,
I have escalated your feedback to a support request. I am not seeing any support request from your account. A member of our support crew will reach out to you soon. -
Always check to see if your Roon server is up to date, sorry beyond that wait for support to get back to you.
Same problem with NAD M10 V2 with BluOS 4.16.6, Roon Tested is shown in Audio settings but no Roon Ready anymore. No problem with my Roon server, router. It is a BluOS bug for sure.
Same here. Node 2i not showing as core. only airplay support.
I had this same problem. Support referred me to Roon support. It wasn't what I expected, as the problem with Roon Ready arose after updating the firmware to 4.16.6. Customer service is a 2 out of 5.
Same problem here with my Node 3 and no solution in two months. Only Airplay 2 connection, no Roon Ready since 4.16.6 update.
I’m not happy with the support either. They also told me that I should contact Roon.
I bought a WiiM Pro last week. What can I say? It was immediately recognized as “Roon Ready.” The device is actually connected to the same switch.
I’m now using it via COAX with the NAD M10 V2, and I’m very happy with it.
However, this also shows me that NAD support doesn’t exactly deserve top marks. I’m seriously considering selling my NAD/BluOS devices and looking elsewhere.
New update 4.16.22 doesn't solve the problem.
Still the same problem with 4.18.18 . Using a Wiim Ultra with no problems at all with Roon.
9 comments
