WiFi not connecting
AnsweredMy iPhone will not pair with my Node v 130. It worked fine until we moved last week. The Node appears connected to the proper WiFi network. But my phone will not recognize the Node in its WiFi settings under ‘Other Devices.’ Been trying to resolve this for 3 days and pretty much as wit’s end with the whole damn process. Have rebooted the Node, rebooted the router, rebooted my phone, reinstalled the BluOs app - all multiple times. Out of ideas.
If this is a new Router, then look at its web interface to see if there is an option called “client isolation” turned on. Might be a similar sounding setting.
You don’t say what make of phone but In the iOS Settings, ensure under Apps that Local Network support is enabled for the BluOS App. In Android there is a similar setting,
