Connecting Two Pulse Flex 2i's to Projector
    Seppi Evans
    To get the picture and audio in sync you do need to use Bluesound products from the Home Theatre range.
    Using Bluetooth, coupled with the inherent delay you might find this quite unacceptable.
    If you have an Apple TV as source connected to your projector you can send the audio via airplay to the FLEX and the audio can be adjusted.
    There might be ways, perhaps another user can chime in.
  • Julian Redding
    Thanks Seppi, it might be the case I need to get a projector that supports BT 5.4 which does allow for multiple devices being connected at the same time. Hadn't considered the potential lag so might need to test/play around to see the impact. I do have an ATV so will try too. Appreciate the response.
  • Julian Redding
    Just as a follow up, The ATV solution does work. The only problem is that I'm in the UK and use Sky. Although they have an app for the ATV, it won't use Airplay so I'm back to square one. I might have to bite the bullet and just buy another soundbar (but not Bluesound as too expensive for the need).
