distorted sound in Pulse 2i
AnsweredAll music is distorted and when the Pulse 2i is in stand-by mode there is a light cracking coming from the speaker.
Remove the power for 30 minutes and see if that helps, if not you could try a factory reset or raise a support ticket using the BluOS App.
