Pulse Flex 2i: Re-Installation after Reset "Incomplete"
AnsweredAfter a complete reset (off grid for 30 secs, keep pushing start/pause key for 30 secs until LED starts blinking red), I am trying to re-install my second Pulse Flex 2i via my Android phone.
As soon as the LED on the speaker is a solid green, I start the process. All seems right: app asks me for WiFi credentials etc., but after some seconds, app says "Install Incomplete" and offers me to repeat the entire process.
After Support advised I should first connect via Ethernet and then do the WiFi connnection process, I did. To no avail. The problem continues and it is the same as above. Factory-reset did not do a thing for me... I am going in circles.
Try Rebooting your router so they both get on the same subnet with the Pulse attached by cable to the router and on the green. Green light is a good thing
