wireless speakers
AnsweredHi, I purchased a Powernode 2i back in 2019, I think Im right in saying it doesnt have a wireless speaker capability? Is there anything I can do other than purchase the 2025 version of Powernode to successfully use your pulse wireless speakers etc, around my home? I have the Bose soundtouch 30 and portable at the moment and they are so useless and now Bose have decided to pull the plug on the cloud so they wont work the same. Hence I want to replace them with a set of Bluesound wireless speakers. Is there a trade in of the older node to the newer one? I am UK based.
Hi Nick,
Your POWERNODE can connect wirelessly to a speaker using Bluetooth but I am afraid this is not an ideal way to use your Bluesound device.
All Bluesound players (streamers, amplifiers, and speakers) even the first generation players can be part of a group in a multipipalyer group which in a way can be considered wireless.
I am afraid I am missing parts of your inquiry and set up. Please feel free to reach out to your local authorized Bluesound dealer and they will be happy to assist you. You can also reach out to our support crew and we will be more than happy to assist you.
