Persistent dropouts on grouped Pulse M speakers (Powernode stable) despite strong WiFi and UniFi setup
    Mark T.
    Sr. Support Crew Member
    Hi,
    I've escalated your feedback to a support request. A member of our support crew will reach out to you in regards to your issue.
  • Leon Latrap
    Hey Tjeerd,
    did you ever find a solution to your problem?
    i am experiencing the same issues.
  • Martijn van Rooijen
    Similar issues here: Since years I am using a Node 2i streamer connected via ethernet cable to the router. Android Bluos apps on my devices are always able to find the Node 2i. This week I purchased a Pulse Flex speaker and connected it via WiFi, and grouped it with the Node 2i. Everything worked fine for 10 minutes, but then the Bluos app lost the connection with both the players. I have restarted router, re-installed the app on both Android phone and tablet. The app found both players again, but after some playing time the connection was lost. This happens mostly when the players are grouped.
