SSD wird nicht erkannt und keine Library
    Permanently deleted user
    When you plug in the SSD the player should notify you, but if it does not you can manually enable the option(s) following the link below.
    BluOS only looks at the first partition so make sure there are no additional or hidden partitions on the SSD drive.
    https://support.bluos.net/hc/en-us/articles/360037137354-USB-Server-Mode-How-to-connect-external-USB-Library-to-the-BluOS-Players
  • Oluwafemi
    BluOS only reads the first partition on a USB drive. Make sure your SSD has a single partition and no hidden ones. Once connected, the player should recognize it, or you can manually enable it following the BluOS USB server guide.
    -1
