Playback Quality Indicator
5 comments
    Niro Man
    When I’m playing my Vault, all I do is touch the HR or CD icon in the app where it shows what’s playing now and it does show the bit and sample rate for me. Doesn’t it do the same for you?
  • Massimo Chiari
    Good evening Mark, thank you for your feedback.
    Don't you think it would be useful for listeners to know more details  by displaying the bit rate and frequency of each individual streaming file? This would make it easier to compare the quality of different recordings.
    Thank you.
  • Massimo Chiari
    Hi, good point! Tonight I'll give it a try with my Nad and let you know.
    Thanks a lot
  • Massimo Chiari
    Good morning Niro Man, thank you so much for your very useful advice! My app works in the same way as yours, and I can view the streaming details by clicking on the icon. You've solved my problem!
    Have a nice day.
  • Niro Man
    Glad I could help
