NAD C658 on Ethernet how do I switch to WiFi?
AnsweredHi...
I have a bad streamer connected to Ethernet.. but the Ethernet is not great... so I want to switch it to WiFi... I’ve found the instructions for connecting to WiFi: add new player.. etc.. but it doesn’t work, if I try and add a player it doesn’t see the player. How do I do this? There is no WiFi set up on the hardware which I find strange in its self?
thanks.
Hi Robert
Please see www.bluesound.com/setup as this will work for all BluOS Players including the NAD C658 - try Manual Setup using a Browser if the app is giving you problems.
NAD streamer... not bad
Thanks Tony..
But like i said: "I’ve found the instructions for connecting to WiFi: add new player.. etc.. but it doesn’t work"
I've tried on an Android.. On an iOS device... Manual: "This site cant be reached"
So need some actual support.Thanks.
R
Hello Rob,
If your C658 is still connected online with the Ethernet, reach out to our support crew using Help > Send Support Request.
Otherwise, please send them an email at support@bluesound.com.
Sam R.0 -
Hi Robert,
I Had the same issue and i fixed is by accessing the C658 at the ip-address through ethernet and did the set up for wifi.
After that i removed the ethernetcable and power cycled the C658. ( AC dosconnect and reconnect)
When a lan cable is detected the device automaticly switches the wifi down.
Hope you can fix this fixed this way.regards,
Arjan
You can also select Settings, Player, Wi-Fi in the BluOS App
6 comments
