Weak subwoofer output
    Hi Oystein
    The issue you describe on another thread was a change we made in BluoS 3.10.0 and reverted in 3.10.3 - no changes have been made ins 3.12.13. I would recommend, checking Settings, Player, Audio, and see if you have My Subwoofer enabled.
    Please check your sub-woofer cable and toggle My Subwoofer off and on. If however, the problem persists, please select Help, Send Support Request in the BluOS App so we may take a closer look at the log file.
