Problem with playing Tidal after removing Adobe Flash Player from iMac
    Hello Nenad,
    That is peculiar. The next time the issue occurs, please send our support crew a diagnostics log via Help > Send Support Request (log will be automatically attached) so they may investigate.
    In the meantime -- do you get any form of error when using TIDAL Connect to stream to your NODE 2i?
  • Nenad Solajic
    Thank you for the quick reply.
    I actually don't use Tidal Connect. I use only built-in Tidal in the controller. And I like it when it works.
    Kind regards,
    Nenad
