Tuneln and national radio stations (NRK)
    Those don't look like their off the Node diagnostics -- is that a Wireshark dump?
    I tested a couple NRK stations including and like Bjørn it seems to work. I'm located in Canada if that makes any difference.
    Edit: just noticed the direct link. I'm not getting any audio when I click on that link, but when I search and play NRK P3 from TuneIN/BluOS, it plays correctly. I would recommend trying the direct search in the BluOS app to see if the same issue occurs.
  • Bjørn Ulvik
    No issues with NRK here. Are you using "Favourites" or adding a custom station?
  • Erik Haga
    Hi,
    I just managed to get it working again.
    I had to reinstall the speaker by doing a factory reset. It was a strange failure because the BlueSound speaker send a TCP reset on the traffic it requested towards NRK servers ...
    After the reinstall it looks better and everything seams to works :
    23:40:46.298438 IP 10.10.0.110.35552 > 148.123.28.98.http: Flags [.], ack 5968143, win 28661, options [nop,nop,TS val 4209068379 ecr 326835802], length 0
    23:40:46.312184 IP 148.123.28.98.http > 10.10.0.110.35552: Flags [P.], seq 5968143:5969508, ack 255, win 1029, options [nop,nop,TS val 326835839 ecr 4209068379], length 1365: HTTP
    23:40:46.328025 IP 148.123.28.98.http > 10.10.0.110.35552: Flags [P.], seq 5969508:5970752, ack 255, win 1029, options [nop,nop,TS val 326835865 ecr 4209068379], length 1244: HTTP
    23:40:46.343668 IP 148.123.28.98.http > 10.10.0.110.35552: Flags [P.], seq 5970752:5970874, ack 255, win 1029, options [nop,nop,TS val 326835880 ecr 4209068379], length 122: HTTP
    23:40:46.343778 IP 148.123.28.98.http > 10.10.0.110.35552: Flags [P.], seq 5970874:5972238, ack 255, win 1029, options [nop,nop,TS val 326835880 ecr 4209068379], length 1364: HTTP
    23:40:46.344960 IP 10.10.0.110.35552 > 148.123.28.98.http: Flags [.], ack 5970874, win 28576, options [nop,nop,TS val 4209068425 ecr 326835839], length 0
    23:40:46.359155 IP 148.123.28.98.http > 10.10.0.110.35552: Flags [P.], seq 5972238:5973604, ack 255, win 1029, options [nop,nop,TS val 326835896 ecr 4209068425], length 1366: HTTP
    23:40:46.374695 IP 148.123.28.98.http > 10.10.0.110.35552: Flags [P.], seq 5973604:5974969, ack 255, win 1029, options [nop,nop,TS val 326835901 ecr 4209068425], length 1365: HTTP
    23:40:46.376181 IP 10.10.0.110.35552 > 148.123.28.98.http: Flags [.], ack 5974969, win 28449, options [nop,nop,TS val 4209068457 ecr 326835880], length 0
    Here is a tcpdump on the FW routing the traffic towards internet.
    Thank you for the help which showed me that it had to be a local error at my speaker.
        - Erik -
