Wireless headphones connection to Vault 2
AnsweredHow can I connect a pair of BT wireless headphones (Apple) to a Vault 2 player? Or is this only possible with the Vault 2i?
Hello Douglas,
This would only be possible on the VAULT 2i.
The only potential workaround would be to look into 3rd party external Analog to Bluetooth Transmitters.
Sam R. -
Thanks Sam. This helps.
