Problems when multiple controllers active?
    Hi George
    If you are using multiple access points, ensure you do not have multiple networks happening. All Bluesound Players and Apps must be on the same network (same IP subnet). Check out www.bluesound.com/network101 or select Help, Send Support Request for network troubleshooting assistance.
  • George Allen
    There are not multiple networks.
    Hi George
    It is still networking related somewhere. Check the tips I mentioned for assistance...
