    Hello Sveinung,
    We have received a small number of similar reports and our QA and Dev teams are currently looking into this.
    In the meantime, we have found that disabling the Volume Limits (via the app, select your player and go to Settings > Player > Audio > and either hitting Reset All to clear all configs, or drag the sliders on the volume limits so that it goes from -90dB to 0) has proven a temporary workaround to prevent this volume jumping.
    We thank you for your continued patience as we investigate the matter.
  • Sveinung Tveito
    Is this fixed in recent updates?
  • Sam R.
    I believe this was fixed in BluOS v3.12.0
