BlueNode 2i BT and ANALOG
    HI Kevin
    You can not use Bluetooth out and Analog out at the same time as Bluetooth is designed for headphone usage.
    The best sonic performance, and easiest way to accomplish what you are doing is to buy a second NODE and group them for perfectly synchronized playback.
