NAD c368 as preamp with subwoofer
AnsweredHello,
I want to use my C368 as a preamp. Seems the C368 has a shared preamp/subwoofer output. How can I use the C368 as a preamp AND connect my subwoofer as well?
The power amp I will be using does not have a subwoofer connection.
Thank you.
Hello Kris,
Unfortunately as the PRE OUT and SUBW OUT on the C368 is a shared connection, this would not be possible without some likely-undesirable workaround (line splitter cable).
Sam R. -
Thank you for the information. That is a pity.
In case of a line splitter cable, will this influence the sound quality or even worse: damage the hardware?0
