Cleaning Node 2 top
5 comments
    Kristofer Hadodo
    Lossless
    For my white devices, I've been happy with a microfiber cloth like this: https://www.amazon.com/dp/B06XNXP67Z/
    I'm sure a black equivalent would work for you. If not, use it for other cleaning purposes. 😇
    Best, KriHad
  • Kristofer Hadodo
    Lossless
    ...just add a splash of water to the cloth.
  • Derek Sewell
    I have several items with this problem, the plastic seems to deteriorate badly, my Power Node is very sticky, my Pulse Midi and The Vault all with the same problem. Bluesound what is the answer.
  • Phil 3100
    It happens to a lot of plastic items over time. I have sunglasses, belt buckles, an umbrella grip, walking pole grips and other items that have done the same. I found advice on the internet to rub with washing up liquid; another suggestion was pure alcohol or acetone. None were very successful. In the end I used a car paint rubbing compound, which completely removed the sticky layer and restored a bright polished surface. I would only recommend that on the Node if you can remove the case lid for treatment though.
  • Richard Stubbins
    I had the same problem - a sticky surface on my Node. As other people suggested, I used Isopropanol, or isopropyl, alcohol 99.9% and a cloth (actually an old T-shirt) and rubbed the surface to remove the sticky rubber coating. This worked well; it only took 20 minutes; it didn't take much effort. The Bluesound logo remains on the front panel. I was quoted £90 for a new casing plus shipping costs. The £9 Isopropyl bottle from Hexeal via Amazon was therefore a bargain!
