Setting up bluesound again on a different WiFi connection
AnsweredI have already set up the Bluesound Vault 2 on a 2.4 GHZ wifi system in my house but now have added some wifi extenders since the wifi signal was not reaching all areas where signal was needed. The system with the extenders has a different wifi address to the original one I used to set up Bluesound.
How do I change Bluesound so that it will work with the new wifi network rather than the former one?
Your attention to this question will be appreciated
Hello Doug,
This one's a bit tricky. If this were a wireless Bluesound player, you would just need to go to the Settings > Player > WiFi and setup your player on the new network name/SSID.
However, since the VAULT is a wired connection, theoretically it should be connected to the correct network so long as it is wired directly to the router. If you have it connected to one of the 'nodes' of your WiFi extenders, you would want to make sure that extender uses the new network name/SSID, and then you would need to connect your phone/computer to that same network name/SSID so that they could 'see' the VAULT.
