How to operate node 2i and pulse flex 2 seperately
Hi,
Just bought a Node 2i and a Pulse Flex 2. Connected the node 2i with pulse flex 2 and analog receiver and speakers. Happy with the sound.
Now I want to make use of the possibility to play two different sources simultaneously, so lets say tv sound (connected through optical out/in) on the analog setup and spotify on the pulse 2. But how do i do this? It probably won't be that complicated, but I can't figure out this configuration. Help on this would be appreciated!
Kind regards,
Borschi
Hi Borschi
Bluesound Players only play synchronised when you group them in the App. By default, they run independantly.
Here's how grouping works; https://support.bluos.net/hc/en-us/articles/360044050794
