Using Vault for movie sound
    Hello Ed,
    If this setup works fine with music cast to the Chromecast, it could potentially be that the audio format of the movie when Chromecast-ed is incompatible with the VAULT+FLEXs group (Dolby perhaps?) or even the Audio Extractor itself.
    I would recommend reaching out to Google to confirm what audio format is being sent over when casting a movie (may be dependent on source being cast from, too).
  • ed
    Thank you Sam. Actually, it is a real nightmare to get accurate information on the audio format with all these devices involved... But it is probably Dolby indeed. I will investigate further.
    Anyways, which format(s) would be supported by the Vault+Flex?
    Thanks again!
  • Sam R.
    PCM Audio would be the way to go
