Connect Node 2 to Harman Kardon power-amplifier?
AnsweredCan I connect the Node 2 to a Harman Kardon HK770 power-amplifier?
The HK770 has an Input Impedance of 35 k Ω
Source: https://stereonomono.blogspot.com/2019/11/harmankardon-hk-770-power-amplifier.html
I don't have the Harman Kardon HK725 pre-amplifier that's pictured above.
Thanks in advanced.
Hello Alex,
The NODE 2 DAC output is 2.1 VRMS, and supports connection to a minimum load impedance of 5kΩ
Sam R. -
Hi Sam,
Thank you for you quick reply.
So there shouldn't be an issue with the minimum load, just wondering though if there is anything else I haven't thought of with the setup?
Kind regards,
Alex
From the looks of it you should be able to run the RCA Analog Out of the NODE to the Line Input on the HK770. On the NODE you wouldn't need to change any settings, and it appears that the HK770 is simply plug and play as well.
Hi Sam,
That's great, thank you so much for your help.
Regards
Alex0
4 comments
