installing a solid state drive?
    The VAULT Harddrive is a specially designed media drive that runs at a slower RPM so as not to generate heat, noise and extend the life of the drive. It is also specially formatted to prevent data loss.
    We are very comfortable and proud of the 2TB drive in your VAULT and do not recommend opening your VAULT there are no user-serviceable parts inside and you will void your warranty.
