Home Theater Group - no sound from rear speakers
6 comments
    Hello Rodger,
    If you are not hearing any audio in the rears while playing Dolby audio, please ensure your TV and Video source are set to Dolby
    You can double-check this in the BluOS App; the Dolby Logo should appear in the Now Playing window. If it does not, then likely these Dolby settings from your TV/Source/Output to the POWERNODE are not set correctly.
  • Rodger
    Thanks for the reply Sam. I spent hours searching the KB articles and this forum and this is the first time I've heard of this Dolby Logo display. I'll check that later today.
    Also, I play some video games that output 5.1 channel PCM. Will the Bluesound Home Theater Group respect the channels that are sent to it via PCM? Because in my testing it still only outputs the front left and right channels.
    This new feature has very poor documentation and lack of software support. Bluesound could save the users like me (who are heavily invested with Bluesound), a lot of hassle by clearly documenting the feature and providing simple 5.1 speaker tests in the app for Home Theater Groups.
  • Rodger
    For anyone else having this problem... I fixed this by removing the NVidia HD Audio driver and using the Microsoft HD Audio driver. After that, i got surround sound from my Nvidia GPU.
  • Casey Stilton
    Can you please give me an idea of how to fix a similar issue. But I have audio when it goes from the home theater itself, but when I try to switch to 3rd party sound system, I have no sound.
    Hi Casey
    In the Audio Settings of your Home Theatre Group, please enable Stereo Surround. See this KB Article for details; https://support.bluos.net/hc/en-us/articles/360059475273
  • Fernando Mujica
    Hello,
    I have the same issue and have not been able to address it.
    My setup:
    Soundbar+
    - Connected to TV via eARC HDMI port
    - Connected to the network via Ethernet
    Amp
    Sub+
    Apple TV 4K
    - Connected to TV via HDMI
    - Settings:
    - Audio Output: TV Speakers (but also tried Airplay2: Temporary Audio Output - BlueSound Theater group)
    - Change format: Off (but also tried On with Format set to Dolby Surround 5.1)
    - Immersive Audio Dolby Atmos: On
    X Audio mode: Auto (but also tried 16 bit)
    Sony TV KD-75X80K
    - Settings:
    - Digital audio out: Auto 1 (but also tried Auto 2 and PCM)
    - Dolby Digital Plus output: Dolby Digital Plus (but also tried Dolby Digital)
    - Pass through mode: Auto (but also tried Off)
    Soundbar+ / Sub+ / Amp Home Theater group
    - Selected Soundbar+ as connected to TV
    - Adjusted relative sound levels (sound comes out of front and rear speaker with the corresponding test)
    - Audio settings:
    - Surround Upmixer: On
    - Virtualizer: On (but also tried off)
    - Volume Leveler: On (but also tried off)
    - Dolby Audio (Dolby Surround) logo appears in BlueOS app in Now Playing
    All the devices have the latest SW version installed.
    The Amp and rear speakers work fine when not in Theater group, as soon as I add them to the Theater group no sound comes out any more despite the Dolby Audio (Dolby Surround) logo appearing in the BlueOS app.  The same Apple TV and content on a traditional AV works fine (sound comes from all speakers).
    I have tried many settings as listed above. Please help.
    Thanks in advance,
    Fernando
