Tone control drop down doesn't show in 3.12.1
4 comments
    Hello Bradley,
    I have escalated your case so that our support crew may look into it more closely.
  • Bradley O'Connor
    I got asked for the info below so sent it then got asked for it again. This is getting almost as frustrating as owning a PlayFi device lol!
     I did the upgrade on both units and nothing has changed.
    I bought both units from Audio Affair in the UK.
    Serial Number of one unit is K206N2iB49930 Serial number of the second unit is K201N2iB39389
    Both units are on iOS App:3.12.1 and BluOS:2.12.6
    Let me know if there's anything else I can try.
    I had an email saying the case had been closed but I have no solution?
  • Gertjan
    Dear Sam,
    Exact same issue here. Only on the Node 2i, both Pulse Flex 2i's have the control in the app functioning correctly.
    Interesting behaviour is that if I turn tone control on - off I do hear the change in sound as previously set, but it 'just' does not show the sliders. Not a big deal as I do not need to make adjustments anyway, but of course not how it should be.
    Noted on iPad and iPhone, both running latest iOS and Bluesound versions.
    Another thing I noticed; just before the latest update I had a slider for the cross over point for the sub, which was new. This has disappeared again in the latest version. Not sure if that is correct (as I do not own a Bluesound sub)?
    Thanks for looking into this and I'll keep enjoying your products in the meantime!
    Kind regards,
    Gertjan.
  • Sam R.
    Hello all,
    From what I can tell, this behavior should be fixed in the BluOS Controller iOS app v3.12.2 that is being rolled out very soon.
