does Node2i work with a Naim NAC 112x pre-amp and Naim NAP 150x power amp?
Answeredi connected with RCA (red&white) cable, and , nothing . I hear nothing.
Song is playing on the BluOS app, but nothing coming out of speakers.
what is wrong? please help
thanks
Hello Jonathan,
Theoretically I don't see any reason why it wouldn't work. Check to ensure the NODE is outputting audio by connecting headphones to the front jack, and if so ensure the RCA cables are firmly attached, and that you switch to the corresponding source on your NIAM amps (all the outputs on the back of the NODE are live so no settings are required to output over RCA etc.)
