Ethernet or Wifi
    Hello,
    Usually even if the speed is the same, you'll find that using an Ethernet cable is more stable (less chance for interference or signal loss [though if running a 100ft cable you'll want to make sure its insulated to redice noise pickup]).
    Alternative to running a wire through the ceiling, you could also consider a Powerline Adapter. I use one to get Ethernet in my basement.
