Sound quality issues with left channel in stereo pair when using analogue input
AnsweredSound quality issues with left channel in stereo pair when using analogue input. With CD player connected to right channel Pulse Flex, left channel Pulse Flex occasionally drops out and also produces occasional 'pops'. Both Pulse Flexes are using wired ethernet. Have tested CD player with different amp and speakers to be sure CD player is not the problem. A/V mode is off. Compressed Group Audio is on. Both Pulse Flexes are updated to the latest version.
Hello David,
Open the BluOS app and, on each Flex (you will need to ungroup them temporarily), go to Settings > Player > Customise Sources > Analog Input > and toggle A/V Mode. Once done on both, group them back again and test.
Sam R. -
Actually, pops are heard in both channels.
