Node 2 gives a solid red light
AnsweredThis morning after selecting to update the node software via the controller app, the node stays red. It is connected to a wired network. Never had issues before with updates. Removed power for 30 s without effect.
Hello Arie,
I have escalated your case. A member of the support crew will be in touch as soon as possible.
Sam R. -
thanks
