Current Best Practices for a Whole-House BlueSound Solution? (2020)
AnsweredI'm completing the build of a large new home and I'm interested in using a BlueSound solution... I plan for 8 or more zones, with wired-in ceiling speakers, ideally to be able to use Dirac for correction (of each room), etc. I will have a central equipment closet off of a theater room. Can someone recommend what would be the best current solution available? Thanks!
Hello Max,
It's likely best to speak with your dealer so they may more closely look at your floor plan and give a more designed recommendations.
That being said, you might want to ask them about the CI580, which is a multi-zone BluOS streamer, or the Dirac Live activated(?) NAD Products, current line up listed below:
