Node 2i wifi issues - Ethernet from PC not Router?
    Hi Geraint
    Networks don't work this way - you will have to send all networking devices to a centralised hub and cannot be daisy-chained. You will have to connect your NODE to the router and cannot have it hang off the PC's Ethernet port.
    Have you considered a powerline adapter?
  • Geraint Evans
    Thanks for the response. To be honest the wifi router is only about 12ft away and one brick wall. The wifi signal is strong for my imac and ‘fair’ for the Node 2i that’s more or less next to it.
