2-way Bluetooth
    Hello Winke,
    Technically speaking you may find that you are able to pair the Bluesound Gen 2i player with a Bluetooth speaker using the Bluetooth Headphone method, and this will direct the output of the Gen 2i speaker to the paired Bluetooth speaker, but it will still be treated as a 'headphone' -- which is to say that all other outputs except the paired Bluetooth device output will still be muted, as if headphones are plugged in/paired.
