Pairing Cleer Flow Headphones with Node 2i
    Hello Christopher,
    When clicking the 3 dots, if you don't see Bluetooth headphones it could potentially mean you don't have a Node 2i but rather a Node 2.
    To confirm, if you check the bottom of the Node, you should see in small letters the model (either Node 2 or Node 2i), or if that is difficult to read, the serial number will have a lowercase 'i' in it (###N2i###) if it is a 2i player.
    Sam R
  • Christopher Keene
    That was it.  Thought it was a 2i.  Paired it successfully with my Vault 2i, however.  So all is not lost.
