How do I connect and external DAC to a Powernode 2i?
    Hi Ben
    The POWERNODE is a self-contained integrated amplifier and has no pre-outs. You can not use an external DAC with it. If you wish to use an external DAC, you can use a NODE and let your ears decide between the NODE's own internal 24/192 DAC or an external one.
