Save volume per input channel
AnsweredHi
I would like to save the last used volume per input channel (i. e. optical in, Qobuz, TuneIn, ...) as each usually has a different gain. Especially, for watching TV (optical in), I have to turn volume up. But for Qobuz, I have to turn it down again. This is quite annoying when switching from one input channel to the other.
Cheers
Freddy
Hi Freddy
You cannot program volume settings based on inputs. You can, however, set a volume level when creating a Preset. Select My Presets in the App and press the Plus sign in the top right to create a preset.
Hi Tony
Thank you for your answer. I know that it is not possible to program volume settings per input channel - this is why I did a feature request ;-)
The preset thing is a good start but not nearly enough. First of all, I never switch to optical in manually but always use the auto-detection. Thus, I have no way to use the preset's volume setting there.
Furthermore, I do not want to be able to use the auto-volume settings for Qobuz only when starting a certain playlist. I want it for any song I start on Qobuz.
Cheers
Freddy
Hello Fred,
Thank you for the followup details -- I will forward this as a feature request to our engineering team for their consideration to include in a future update.
Sam R.0 -
Great, thank you very much!
Yet, no solution was provided :(
5 comments
