    Wesley P.
    Hello Davide,
    The buzzing you are experiencing in this video is most likely due to the internal amplifier of the active speakers being used. What I would suggest to verify this is to try connecting another pair of speakers to see if this same issue persists.
    If you do not have another pair of speakers to test, try connecting a pair of headphones to the front headphone port of your Node 2 to see if the same buzzing occurs.
    If you are noticing the same buzzing on multiple speakers and your headphones, please contact our support crew directly at support@bluesound.com for further assistance.
    Wesley P.
