Tips to keep battery pack in best shape
    Wesley P.
    Hello Vincent,
    You shouldn't have any trouble keeping your Pulse Flex connected to your BP100. However, if you would like to ensure the longevity of the batteries of the BP100, I would suggest disconnecting the BP100 from your Pulse Flex when you are not charging or using the battery pack.
    Wesley P.
