Problem with volume
AnsweredI have de bluesound NODE 2i.
If I use the app on my Iphone or Ipad I can control the volume without any problem.
If I use program on my laptop the volume control doesn't work very well. Is this problem know by anyone?
Hello Erik,
From what you have described, this issue is most likely due to the speed or connection of your computer. However, if you would like a member of our support crew to take a closer look into this for you, please contact them directly by going to Help > Send Support Request through the BluOS app or by emailing us at support@bluesound.com.Regards,
Wesley P.
