I'd like to understand better how Flex 2i works ...
4 comments
    Regardless of the source or how they are grouped, Bluesound players communicate with each other using your home networking TCP/IP Protocols.
    Keep it simple. If you can run a cable, always run a cable. Connect your laptop using the wired line in if you can as there will be far less interference or problems.
    If you are using the headphone output of your laptop, you are using Analogue in. In which case your signal is converted to 24/96 digital and then back to analogue.
    We are here to help, also feel free to use Help, Send Support Request in the App for more 1 to 1 troubleshooting for your specific environment.
    If it sounds great, then enjoy.
  • info
    Thanks a lot for the answers, but two elements still unknown -)
    1) If I connect the players directly to the ethernet ports present on motherboard's desktop (without using external router/switch) I assume that i need to use a ethernet cross cable (not the standard ethernet cable normally used to connect to a router/switch). OK, I can test myself but I'd like to have your answers.
    2) In case I use ethernet connection (you said should be better) I suppose I have to disable some WI-FI configuration using App or is it automatic or is there are default preferences?
    3) Why, connecting a headphone to the rear player port I cannot earn music?
    Thanks in advance
    Ciao
    Claudio Ferroni
  • info
    OK I said TWO and I asked for THREE .....
    1) No - standard network cables connected to the router or switch, the same you would use for a laptop
    2) No - If a wired connection is used, wireless is automatically disabled - it's an either/or situation
    3) If you are using the headphone jack the external speakers are disabled for yours (and others) privacy
    -1
