Node 2i and bluetooth
5 comments
    Wesley P.
    Hello H,
    When using Bluetooth headphones with your Node 2i, you will need to open the BluOS app and reconnect to your Bluetooth headphones after they have been powered off. However, your headphones will be saved to a list of recently connected devices to prevent you from having to wait for Bluetooth discovery to find your device again.
    Wesley P.
  • Todd McLean
    I cannot get my Sony WH1000XM3 headphones to show up in the Player Selection Drawer on my Node 2. Any ideas?
  • Jan van Boggelen
    First you must connect the Sony WH1000XM3 with the Node 2 by NFC (just once).
    See user manuals Sony and BlueSound.
  • Todd McLean
    There are no instructions regarding an NFC connection in either of the manuals. In fact the manuals in both cases are extremely disappointing. Please provide the necessary instructions directly so that I can make the connection. Thanks.
  • John Baxendale
    Did Todd or anybody else find an answer to this?  I am having the same problem with Node 2i and the XM3s.
