Connecting TV with 3.5m jack or digi coaxial
AnsweredI would like to play my TV through my Bluesound Node 2i (I am using my Node 2i for my Flac files stored on a NAS drive but I'm also using the Node 2i preamp connected directly into two Audiolab poweramps) but my TV only has digital co-axial out and and a.3.5 headphone out. Can I connect with either of these forms of connection?
Thanks
The headphone jack will work but not ideal... I had a similar problem back when the original PULSE came out. You can get a COAX to TOSLink adapter on Amazon or at a local consumer electronics shop. They usually run in the $30-50 range for a half decent one and will require AC power generally...
Great. Thanks
