Bluesound node 2 no WiFi or BT connection possible- factory reset doesn't help
    Wesley P.
    Hello Alex,
    I'm sorry to hear you have been experiencing issues with your Node 2. The issue you have described is not one which I have seen before and I have escalated this to our support crew to investigate further.
    A member of our support crew will be reaching out to you shortly and work to provide a solution for you as soon as possible.
    Wesley P.
