aansluiten op yamaha receiver
AnsweredBeste, heb rxa840 yamaha receiver en zou der graag node 2i op aansluiten. Werken deze dan ook samen op bestaand yamaha surround systeem? En kan ik deze dan ook gebruiken voor streaming en internetradio?
Courtesy of Google Translate;
Dear, have rxa840 yamaha receiver and would like to connect node 2i to it. Do these also work together on an existing Yamaha surround system? And can I also use this for streaming and internet radio?
Hi Geert
The Bluesound NODE 2i will allow you to listen to a number of integrated streaming services, Internet Radio via TuneIn.com, Bluetooth and Apple AirPlay. It will playback up to 24/192 over 2.1 channel audio. It will depend on your AVR as to whether or not and how that is distributed in a multi-channel environment.
