Add DLNA renderer support, separate from multi-room audio
AnsweredI know this feature request comes up frequently for BluOS, with the standard response that UPNP/DLNA is not up to the task of synchronized, multi-room audio.
That response is understandable, but ignores the fact that there may be a customer base that's nevertheless interested in SINGLE ROOM playback.
Is there a reason outside of synchronized playback not to implement renderer support in BluOS devices?
2
Hi Lovells
There are a number of reasons why we favour SMB (Windows File Sharing) over UPnP/DLNA
- SMB is more stable and is a onetime connection – it does not require recreating at every boot
- SMB takes less network bandwidth so creates less jitter and timing issues when grouping multiple players never mind when receiving from the server
- SMB does not require special 3rd party software and is native to Windows, macOS and all Network Attached Storage devices (as Windows File Sharing). It also works with Linux if SAMBA is enabled
- DLNA does not let us build a local library database of music so you can;
- Display by Artist, Album, Song
- Sort by alphabetical or release date
- Filter on CD, HR or MQA content
- Provide visual cover art quickly and dynamically
- Make it searchable to easily locate what you want on large libraries
Today you may be interested in only Single Room Playback... ...but tomorrow is another day.
