BlueSound Vault 2i - Re-indexing
    Wesley P.
    Hello Nick,
    The option to delete and rebuild your current index is located by going to Help > Diagnostics > Rebuild Index. This will take a while longer than a standard re-index but will also ensure the index reads any update metadata.
    If a rebuild does not help to resolve this issue, please contact our support crew directly at support@bluesound.com to investigate this further for you and help find a solution for you as soon as possible.
    Wesley P.
